radio, clock, interior light
Old 11-25-2007 | 11:48 PM
sharkracer1989's Avatar
Default RE: AUDIO&ROOM LP FUSE
hey man my car has the same set up wit the two fuses i havent tried takin it out at all yet but if u tried messin wit the tabs and the whole box moves maybe try taking a screwdriver and push down next to the fuses to keep the box from moving not sure if it will work but maybe its worth a try and smart thinkin on not usin too much pressure
  #12
Old 11-26-2007 | 04:48 AM
Michaels10's Avatar
I was trying to see if there are tabs facing inside or outside into the yellow partbut I could not see
Its in there pretty good
  #13
Old 11-26-2007 | 11:35 AM
retsam's Avatar
I just finish installing my Remote Car Starter and I have by mistake blow the Ingnition Fuse (30 Amp) and my radio and Clock whent dead...
Replaced the fuse all Radio and Clock work again.
It's not always the mark fuse for what your are looking for.
Regards,
RetsaM
  #14
Old 11-27-2007 | 10:11 PM
Michaels10's Avatar
No this is the fuses I am looking for might try a tweezer to pull them out
  #15
Old 12-08-2007 | 11:37 PM
Michaels10's Avatar
anyone have sugguestions here!
  #16
Old 01-02-2008 | 09:18 AM
kickinastro1's Avatar
My air bag light came on the other day, now my headlights don't work and the radio sound goes off. If I flip the turn signal a time or two the radio sound comes back on. Could this be in the headlight switch???
  #17
Old 01-02-2008 | 08:55 PM
madindian1's Avatar
those two fuse in the yellow tab in the engine compartment fuses are called power connector fuses. they are left unplugged when the vehicle is shipped so that the battery does not drain it's voltage.
as regards tothe airbag light it could be a gazillion reasons why that light is on. it could be a harness connector. simpliest fix is to take it to the dealer.
  #18
Old 01-02-2008 | 11:45 PM
Michaels10's Avatar
Well I got the yellow thing out I just pulled real hard and it came out w/fuses and I left yellow piece out and put fuses back The reason I wanted the fuses out was to disconnect my factory cassette player with the tape stuck in it reading ERROR 8! but it did kill the power to it and when I put the fuses back it still read ERROR 8 and tape is still stuck in it ...it is one of those ipod connector cassettes and it worked great for awhile!!!!!!!
  #19
Old 01-03-2008 | 12:18 AM
madindian1's Avatar
best thing you can do is take the radio out or try to use something can get the tape out. the ERROR 8 is normally an eject malfunction. so either you try to get it out or buy a new one. next time just disconnect the batt. turn the key on then reconnect the battery. does the same thing or pull radio fuse. simple
pamador
07-19-2020 08:12 PM
grantsolo
04-09-2013 04:06 PM
brad13
06-11-2011 07:03 PM
kyletexxas92
04-29-2010 06:44 PM
awsnap
01-04-2008 12:12 PM
