Rough idle and stumble?????
Alright i got a 2006 Accent, it has 100k miles, when its at idle or driving it sometimes stumbles. but sometimes dosen't. There is no check engine light. ideas???? It also gets worse when ac is on.
Heres the only ideas i haveadd more or tell me im wrong on some of these
Coil packs
spark plugs
PCV
TPS(would it send code?)
Fuel pump/filter (where is valve to check pressure? and how much pressure should it have?)
anything else.......
Coil packs
spark plugs
PCV
RE: Rough idle and stumble?????
If there is no codes, first verify the "check engine" light is indeed functioning by turning on the key and looking to see if it lights for a few moments. If it flashes ok, then take your car to Autozone for a free code scan just to verify there is no trouble codes. If there is no codes, then the likely problem is fuel starvation. The logical next step is to do a fuel pressure check, but to do that you need a special tool. Have you ever replaced the fuel filter? It's probably a good place to start.
2006 > G 1.6 DOHC > Fuel System FUEL PRESSURE TEST
jassmith
03-01-2008 07:16 PM
