running rough
Old 03-22-2006 | 07:35 PM
vtbob's Avatar
Default running rough
Hi, my daughters 2000 accent is running terribly rough at speeds up to 30 or 40. Then it smoothes out. I narrowed it down to cylinders 3 and 4 and am sure its the injectors. My question....can i solve this by dumping a few cans of injecter cleaner in the tank...or should I install new injectors...and how big a job is that? thank in advance.
Old 03-23-2006 | 07:26 PM
flave1's Avatar
Default RE: running rough
first things first have you started by checking the ht leads for tracking and also the plugs for wear/gap?
Old 03-24-2006 | 03:24 AM
vtbob's Avatar
not sure what the ht leads are.....but i know last fall i replaced the plugs and wires with a good quality set. and just today i pulled the injector wires on all 4 cylinders and noticed NO change on cylinders 3 and 4 when i pulled them.....this tells me both those injectors are bad as there was no change when i pulled the wires yes?
vtbob's Avatar
Old 03-24-2006 | 01:16 PM
Brant's Avatar
I would drop in a good quality fuel injector cleaner, fill the tank with super unleaded, and if the car can be trusted, take it for a good cruise. No stop & go driving. Full bore at 65 -70 mph for about a good 20+ miles. That should have a positive affect on your dirty injectors.
Good Luck,
Brant
akaTink
09-21-2010 09:43 AM
Sonata04
06-07-2010 08:18 AM
jamesjohnson56
08-30-2009 08:47 PM
flicker
12-11-2008 05:00 PM
skipi
11-30-2008 04:25 PM
