So whats the trick to get the oil drain plug to stop weeping oil?
I just did an oil change today and put 5/30 synthetic mobil 1 in today and went to the hyundai dealership and picked up an oil filter with the oil drain plug washer that goes with it, Anyway I wrenched down on the plug as tight as it will go without stripping it but the dam thing is weeping oil, not much but enough to annoy me. Any advice on how to fix this problem?
thank you
thank you
thank you
thank you
Also, you didn't say what vintage Accent you had. Synthetic oil is a great solvent for de-sludging an engine, so much so that I have heard of filters plugging on engines 7 to 10 years old. Keep an eye on the oil pressure. The Hyundai filter is a good filter, so the bypass should work to specs and keep oil flowing.
Is the washer specific to different model years? I have a 2002 and have been doing my own oil changes for over 5 years and never needed the washer. I don't leak oil and I don't recall the DIY in the owners manaul mentioning needing one.
