Tibron engine into 2000 Accent difficulty???
Old 05-15-2006 | 11:15 PM
SlowAccent's Avatar
Default Tibron engine into 2000 Accent difficulty???
Hey, I just joined so this my first post. I've owned this car for 2 years and it's been my work car that I've put mad kms on and I may decide to put a bigger engine in this little car. I own a Nissan 240sx that I've done a motor swap on, and it was pretty staright forward with all the help I had.
Now I've read that the Tibron engine is the regular engine to swap in the accent. How difficult is this and where can i find a good page do some homework on?? Havn't really found anything. Is it true you don't require a tibron ecu, and as far as mounting the engine is there welding required or mounting relocation needed to fit it, and how difficult is the wiring??
As you can see I know nothing about this so maby a good link would be very helpful...
Cheers
Old 05-18-2006 | 10:48 AM
poacher's Avatar
Default RE: Tibron engine into 2000 Accent difficulty???
The Tib swap isn't that difficult. It is true that the Accent tranny and ECU will work with the Tib engine. The wiring is as straightforward as it gets. I havn't found any online cheatsheets but have done it successfully. Transaxle is the biggest headache it must come from the Tib and be cut to fit. The side mount will need welded into place as well. Sorry for the short answers I have fifteen mins. left of my fifteen hr. shift right now. If you have any questions just post and I will answer when I am awake.
Old 05-20-2006 | 03:06 PM
SlowAccent's Avatar
Hey thanks for the reply poacher, I actually ended up finding lots of valuable information on the Hyundai Performance Forums, and now have gained tons of general knowlege on Hyundais, so over the summer I will try and collect everything I need to take on the beta swap, come winter-time I'll be working on it and bring it out in the spring next year...Cheers
Old 05-24-2006 | 03:57 AM
cslsxpistol's Avatar
http://hyundaiperformance.com/forums/topic.php?t=61323
Roth52
12-16-2014 02:54 PM
pappy2002
09-23-2007 01:12 PM
sssexy70
08-16-2007 04:06 PM
Chyvalri
02-01-2007 12:59 PM
ddown
06-21-2006 01:04 AM
