timing belt won't fit
Old 12-31-2007 | 07:27 AM
shawnboy's Avatar
Default timing belt won't fit
I'm replacing my timing belt. The new belt is slightly short with the amount of slack needed to fit back on. Is this due to it's a new belt? It has the same amount of teeth as the old belt.
Old 12-31-2007 | 08:40 AM
madindian1's Avatar
Default RE: timing belt won't fit
what you might have to is go from right to left or conterclock wise when you are putting on the belt that way there is no play in the belt on the side that is opposite the tensioner. also you have to make sure the timing belt tensioner is retracted where the belt will be easy to go on.
Robin Hood
03-14-2022 03:24 AM
xjdubber
03-02-2018 01:30 PM
n8rockerasu
05-06-2012 06:48 PM
brensec
09-23-2009 05:11 PM
Rhondas
10-15-2008 08:09 PM
