tire pressure monitor reset on accent
HEY OUT THERE I'M NEW TO THIS SITE AND NEED A LIL HELP! MY MONITOR WENT ON ONCE TO LET ME KNOW OF LOW PRESSURE, WENT AND FILLED TIRES, THOUGHT THE MONITOR RESET ITSELF, GUESS NOT, TIRES ARE LOW BUT NO WARNING, HOW DO I RESET THIS MONITOR?? 2008 ACCENT HATCHBACK. ANY HELP WOULD BE GREATLY APPRECIATED!!
First, welcome to the forum.
Second, please turn off the caps lock.
Third, what are you asking? Is your TPMS light on or not? First you said it was on and then no warning. Are your tire pressures low or not? First you said you filled the tires then you said the tires are low. Please be more specific about the problem. Is the warning light the "TPMS" light or the light with a tire and an exclamation point?
The tire with the exclamation point in it
I didn't post originally but I've got the warning light witht the tire with the exclamation point in it illuminated. I checked the tire pressures and one of the rear tires was at 29 psi so I topped it up at 32 psi but I've still got the warning light. Is there an easy reset?
