Trans Problem...
Old 04-27-2004 | 03:01 PM
frensel's Avatar
Default Trans Problem...
<IMG src=smileys/smiley2.gif border="0">Hy there,</P>
i'f got an accent 2002 gl, i'm having problems with the a/t. When the car is hot, the trans stays in hyshift.</P>
can someone help me with this ?</P>
Old 09-09-2004 | 03:59 PM
speeddemon2026's Avatar
does it not go into overdrive? if so my guess selinoid problem and burnt trans fluid. i've gone thru 4 autotrans already should of bought stick like my ma told me<IMG src=smileys/smiley7.gif border="0">
Old 10-20-2004 | 11:13 AM
Dr. Hundi's Avatar
I am sorry that you have gone through so many transmissions, but the replacement is not neccessary.</P>
The bands and clutches within these automatic transmissions are sensitive to incorrect fluids. Hyundai SPFIII is to be used only.</P>
The other reason in your transmission staying in 3rd gear is because of the reed switch within the speedo head. The name for the action that is happening, when stuck in high gear, is called Limp Mode.</P>
What you will be required to do is to take your vehicle to your nearest Hyundai dealer and have them check your Data trouble codes and verify what I have just told you.</P>
If you can get a hold of the codes and let me know what they are I may be able to help you alot more.</P>
crazydriver91
11-08-2010 06:33 PM
nadel
11-19-2008 03:27 PM
tractorboy
10-27-2008 01:35 PM
gator
02-12-2007 12:28 AM
Warlord
04-19-2006 08:20 PM
