Transmission fluid flush or replacement for 2003 Accent?
I have a 2003 Hyundai Accent with about 150,700 km (93,640 miles) on it. When getting the oil changed today, it was recommended that I get a transmission fluid flush soon because the fluid is dirty. I checked it and it's brownish, but no burnt smell (there was a very slight odour to it, but definitely not burnt). I've never had the fluid replaced or flushed before, and I'm not sure what I should do based on the age and mileage of my car. I've heard a flush will loosen up gunk and mess up the transmission, but I've also heard just replacing it isn't good enough. Any advice is appreciated!
The original fluid is a red color, if it's now brown, then in my opinion, it's toasted & should be changed. I've tried some of the compatible brands but have had problems with these and went back to getting the real stuff from the dealership - a bit more expensive, but it lasts and I get no residual effects.
Although a lot of shops will just drain the transmission and refill it, I'd recommend dropping the pan and changing the filter at the same time - you'll find several magnets stuck to the pan, clean these before replacing the pan. A word of caution: DO NOT OVER TORQUE the pan bolts, the flange on the transmission is very soft and the threaded bolt holes will strip easily - I think the torque is only about 6 to 8 foot pounds, so go easy.
2003, 60000, accent, bad, burnt, fluid, fluids, flush, good, hyundai, miles, put, tranmission, transmission, transmmission
