What would cause my heater control knobs lights not to come on?
Old 04-06-2009 | 11:46 PM
thx1971's Avatar
Default What would cause my heater control ***** lights not to come on?
Everything else lights up,A/C,hazard, defroster, speedo lights ,but not the heater lights ?Can those lights blow out or is that rare?What should i look for that would cause it
thank you
Old 04-07-2009 | 06:04 AM
jsinton's Avatar
Banned
Probably the little bulb blew out. Did somebody replace the radio or take apart the dash?
Old 04-07-2009 | 07:00 PM
thx1971's Avatar
Yes some one put in a pioneer system
Old 04-07-2009 | 07:39 PM
jsinton's Avatar
Banned
Might have something to do with it.
Old 04-09-2009 | 03:58 PM
fannatick2's Avatar
I’ve had the same problem, as well as my dash lights went out. Although I don’t have any insight on fixing the problem. I can warn you than the dealership charged me $90 to tell me that my dash lights and my heater lights, that had been out for 4 months, was an “intermittent” problem that they could not remedy.
Old 04-10-2009 | 11:58 AM
stlwaco's Avatar
If the whole display went dead at one time, it most likely is not the bulbs/LEDs. You wil need to find a print out of the connector view for the controller.Find out which wire is light control and test it to see if there is current flowing thru it. If not, the problem lays further back. If there is, then the problem will lay within the controller and you will need to first look to see if it contains replacable bulbs. If they are not replaceable, then you will need to replace the unit.
swetalgajjar
06-05-2023 06:40 AM
RJOttman
08-12-2011 11:57 AM
jpdulin
02-25-2009 11:54 PM
William Young
06-09-2006 03:03 PM
Quick Reply: What would cause my heater control knobs lights not to come on?
