Where Is The Oil Pan Drain Plug??
Old 08-29-2008 | 01:41 PM
Charlie1969's Avatar
Default Where Is The Oil Pan Drain Plug??
Yesterday, I was to change the oil inour 1.6 liter2007 Accent. I accidently drained the tranny; the pan looked just like an oil pan!
Anyway, I see two other plugs that look nothing likeany oil pan I've ever seenand want to be certain I get the correct one.
I believe it is on the passanger side,cast aluminum with cooling louvers in the bottom, close to being under the oil dipstick with the drainplug facing rear. Is that the oil pan?
Old 08-29-2008 | 01:53 PM
Default RE: Where Is The Oil Pan Drain Plug??
That sounds correct.
Part #5 is what you are looking for:
Old 08-29-2008 | 01:59 PM
Whoot! Thanks, man.
Old 08-29-2008 | 09:54 PM
ken99's Avatar
Did you pour what came out back into the transmission? or buy new transmission fluid? If this car has an automatic transmission, be aware that Hyundai uses a proprietary ATF called SP-III developed by Mitsubishi. Nothing else, including so called "universal fluids", are compatable.
Old 08-30-2008 | 01:31 AM
Doohickie's Avatar
Yep. It needs to be SP-III.
Old 12-13-2008 | 10:09 PM
korbynlehr's Avatar
Do you have a similar drawing for the transmission plug too you can post?
Old 12-14-2008 | 03:04 PM
Carnac the Magnificent isn't a member here. Please tell us what car, model year and transmission.
Old 12-14-2008 | 06:54 PM
korbynlehr's Avatar
Sorry about that. Mine is a 2009 Accent with manual transmission.
Old 12-14-2008 | 08:42 PM
2009 manual trans:
Fill plug:
Drain plug:
glassfern53
09-05-2015 03:47 PM
turkishgold
12-31-2009 03:40 PM
Jagson75
07-29-2009 10:15 PM
thx1971
06-17-2009 08:19 AM
danieleonharper
03-18-2009 04:11 AM
