Window Problem
Window Problem
I have a 1996 Hyundai Accent hatch back with manual windows.
The driver side window can not be rolled down cause the clips that hold the window were replaced incorrectly. I had the error corrected but now the clips have cracked and they were fixed with an apoxy. The apoxy has cracked and the window it barely holding on by a thread.
Everyplace I go, whether it's a dealer or mechanic or junk yard, all tell me I have to replace the glass but that is not the problem.
Man who can you trust? Is there any way I can fix this problem without replacing the glass.
By the way, the passenger window is also starting to go. When I roll the window all the way down it goes off the track and won't roll up again. The only way I can roll it back up again is if I hold the window in place and spread the rubber apart that seals the window so it does not go off track. Any solutions for this problem?
Thanks!
Thanks!
