Your my last hope.
Your my last hope.
I'm really having a hard time with replacing my timing belt. Everything was going cool. Until I tried to relieve some tension on the timing belt tensioner. I'm trying to remove the timing belt. First I need to relieve some tension to loosen the belt enought to slide off. I remove the pivot bolt on the right side of the tensioner and tried to move the entire tensioner over to the left to relieve some tension. It would not budge at all. I tried to put a screwdriver and pry bar on the side to move the tensioner and that did not work. I thought may if I loosen the bolt on the left side then I would be able to move the tensioner. However, the bolt will not budge. I tried a breaker bar and serpentine tool and both didn't help at all. I;m turning so hard I feel like i'm unthreading the bolt and my socket. I think the bolt is so hard to move because of the spring in the bottom of the bolt. It might be pushing against the bolt. I hope I explained my problem. Please any help is greatly appreciated.
jo_6466
07-31-2007 06:36 PM
