2006 Azera 3.8L Spark Plug Replacement
Removing the upper intake manifold (AKA surge tank):
INTAKE MANIFOLD
1.Disconnect AFS(A) and breather hose(B).
2.Remove air cleaner upper cover(D) and intake hose(C).
3.Disconnect RH oxygen sensor connector(A).
4.Disconnect RH injector connector(A) and ignition coil connector(B).
5.Disconnect PCSV connector(A), MAP sensor connector(B) and PCSV hose.
6.Disconnect ETC connector(A) and knock sensor connector(B).
7.Disconnect water hoses(B) from ETC.
8.Disconnect PCV(C) hose.
9.Disconnect brake vacuum hose.
10.Remove surge tank stay(A).
11.Remove connector bracket(A) from surge tank.
12.Remove surge tank(A).
INTAKE MANIFOLD
Not hard,, get the upper plenum off and have at it.. just a handfull of bolts.
Install new NGK IRIDIUM only !! Tighten to 20lb-ft
Out of NOVA' instructions.....
#3 -- leave the sensors plugged in and attached to the bracket,, just remove the 1 bolt that hold bracket to plenum (#10)..
#4 -- remove bracket from plenum, unplug coil lead, and take all 3 coil out with harness attached when time come.
Skip #6 and #7
#8 -- remove the rubber hose for at top of throttle body, remove brake booster hose, and remove the bolt "A" at bottom of throttle body.. then remove the 3 bolts holding throttle body to plenum.. look at my pics as to how it should look.
Skip #6 and #7
I GIVE UP !!! How do I disconnect the AFS connector as shown in Step 1 ?? I have searched through both volumes of the Azera Factory Service Manual as well as looking through many posts on this forum but can't . There must be some sort of tab on the underside that must be depressed before the connector can be disengaged... but I can't find it. CAN ANYONE HELP !!! Thanks so much !
itsthebigb19
03-15-2010 06:45 AM
