Hyundai Azera A Hyundai like you've never seen before.
Back windshield sun guard
Old 06-26-2010 | 10:54 AM
kdog88's Avatar
Default Back windshield sun guard
My sun guard will not go down when in reverse.....it stops and makes a loud buzzing noise. Is this covered in the 100,000 mile warranty?
Old 06-26-2010 | 04:51 PM
No. The 100,000 mile warranty is for the engine and trans. The sunshade would be part of the 5 year / 60,000 mile warranty.
Old 06-26-2010 | 09:23 PM
Sunshade is 5/60 item,, some had recall to replace gear inside, big PIA... what couple we got the tech would break the screws for the cover, then install new shade assembly..
Warranty paid 6 minutes beyond the normal replacement time of the shade, and you had to wire up the thing to partially extend it mid travel, take it apart, change the gear and make sure it was all in time.. HA !!
Break it and install new shade. I seem to recall that Hyundai ended the recall on sunshade gear... might drive through Hyundai service aisle and ask service rep to check VIN on WEBDCS..
Send me VIN, I can run Monday morning.. do not post VIN on-line.
Old 06-26-2010 | 10:39 PM
Original TSB: 07-90-004 AZERA REAR POWER SUNSHADE ABNORMAL NOISE OR BINDING DURING OPERATION
Revised TSB: 09-BE-022 REAR POWER SUNSHADE ABNORMAL NOISE OR BINDING (see link below)
TSB: 09-BE-022.pdf
Old 06-27-2010 | 08:44 AM
kdog88's Avatar
Thanks guys! Since there is a TSB out on this.......is it then covered under warranty??
sbr711.......how should I send you my VIN??
Old 06-27-2010 | 11:00 AM
TSB is only an internal memo saying here is how to replace, what to do or not to do.. it is not a warranty repair unless you fall into the applicable warranty... in this case, 5/60... only coverage beyond that is if it is a recall item, then recall is valid as long Hyundai decides to keep it open.
sbr711.......how should I send you my VIN?? --> Click the link : https://www.hyundaiforum.com/forum/p...=newpm&u=10814
Send VIN via the link, should go to private/instant message thing
Old 07-04-2010 | 07:05 PM
1eugene445's Avatar
Default Rear Sunshade repair
Mine also broke, but my car is still under warranty (2006 with only 17,000 miles.) Dealer repaired it with no problem or cost to me. They said the gears had stripped.
Hockgwai
10-01-2013 11:15 AM
hed1117
11-02-2011 11:07 PM
DrDemento
06-27-2010 05:23 PM
k309
06-18-2006 04:39 PM
HUSTLER2677
03-31-2006 04:47 PM
