Hyundai Azera A Hyundai like you've never seen before.
Problem with lights dimming
Old 12-08-2012 | 01:16 PM
fsupat24's Avatar
Cool Wire Bypass Headlight Dimming Issue
Just curious, experiencing the same headlight dimming (and other losses of power) issues in my 2006 azera. Was wondering if the wire bypass worked... Is it simply connecting a 4 gauge wire from the positive contact on the alternator to the positive contact on the battery? Do I need to ground the wire? Thanks for the insight.
  #12
Old 11-27-2014 | 05:40 PM
jcouelle's Avatar
Question problem with lights dimming
Regarding solution offered by GREGBR post #10, 08-15-2011, i.e. connecting a wire from the alternator directly to the positive battery post, is there not a risk of possible damage to the electrical system if you don't install a fuse on that wire? If so, what size should that fuse be? I note in the fuse box next to the battery, a 150 A fuse for the alternator.
briancroston
08-15-2012 03:15 PM
mbm
11-06-2010 09:25 AM
jsi
10-16-2009 12:23 AM
danimg3
12-02-2007 07:51 AM
toolazyforalogin
02-13-2006 01:15 AM
