Hyundai Coupe The European version of the American Tirburon.
No tail lights!
Old 01-02-2008 | 11:48 PM
de2r's Avatar
Default No tail lights!
I really hope someone can point me in the right direction on this. I suck at electrical problems. The story so far ....
The car is a 1993 SCoupe Turbo. My son bought this as a secondary vehicle for the winter.
Headlights work -buthe hasno tail lights, parking lights or dash lights. I'm suspecting that this all is on the same circuit. I have checked the fuse panel under the dash and didn't see a fuse designated for the tail lights or the cluster. I checkedthe fusible links under the hood and they're good. I checked the tail light bulbs and the filiments are in tact. I checked the ground for thislighting assembly and its good. I bought the only manual I've seen available on this vehicle -the Chilton Hyundai Coupes/Sedans 1986 - 93. It might as well be in latin because the book is vague at best. Does anyone have any suggestions or methods I could try to pinpoint the problem and fix it. He just moved out and needs the car to commute.
Thanks in advance.
Old 01-03-2008 | 03:57 PM
madindian1's Avatar
Default RE: No tail lights!
i'm not really familiar with the car but if all fuses and bulbs are good, use a test light and check at the sockets to see if you're getting power/voltage. that way you can back track, check behind the socket and remove the bulb to see if it's a voltage problem or faulty socket. it could also be a connector both harnesses plug into for the tail lights. just my 2 cents
Old 01-03-2008 | 07:36 PM
de2r's Avatar
Thanks madindian1. I thought about that today. I was hoping it would be a simple burnt fuse somewhere.
Old 01-04-2008 | 07:08 PM
madindian1's Avatar
no problem
psychodoodbrij92
03-28-2019 12:54 PM
msvg
05-25-2006 01:29 AM
GFont
05-14-2006 08:14 PM
msvg
01-27-2006 04:11 PM
accentgsi02
11-29-2005 10:57 PM
