Hyundai Coupe The European version of the American Tirburon.
OVER RUN ?
Old 09-23-2006 | 10:07 AM
richie's Avatar
Default OVER RUN ?
Got a 1.6 coupe,think its great.However it does seem to have over run ie when dipping the clutch to change gear the revs seem to hold before dropping slightly later even though the accelarator has been lifted.Have also noticed that sometimes when slowing down and depressing the clutch the revs seem to slightly increase momentarily.Anyone got similar problems or know the cause ?????
Old 10-17-2006 | 10:13 AM
richie's Avatar
Default RE: OVER RUN ?
Just got car back from its first service.Apparently the cause is a faulty throttle position sensor,which is now on order.Is mine the only car to have this problem??
Old 10-18-2006 | 07:29 PM
blueboy_ju's Avatar
no my 2.0 SE also seems to do the same, also mine idles too fast just below 2 on rev conter any ideas for me.
Old 10-19-2006 | 03:41 PM
richie's Avatar
I'm having the new sensor fitted tomorrow (Friday).I'll let you know if it makes the difference.
Old 10-19-2006 | 05:43 PM
blueboy_ju's Avatar
OK THANK U VERY MUCH I WILL KEEP LOOKING.
Old 11-01-2006 | 06:02 PM
richie's Avatar
Sorry about the delay in replying.
Had the new sensor fitted and it now runs sweet.Free Revving and no overrun.I'd get yours done if poss.
Old 11-07-2006 | 04:39 PM
blueboy_ju's Avatar
thanks for the info just dropped car off at garage lets hope it works on mine.
Old 09-27-2007 | 02:55 PM
richie's Avatar
Hi again
Did the garage solve your problem.I thought that it had solved mine but have since been experiencing the same problem.Mine seems to be holding the revs when I change gear,almost as if it were on choke.Sometimes when I accelarate hard,the engine seems to find a flat spot and does not accelarate smoothly ?
Old 10-01-2007 | 03:33 PM
Doohickie's Avatar
If the engine rpms do not drop right away when you take your foot off the accelerator, that's not a bug, it's a feature. The Idle Air Controller (IAC) purposely holds the rpms up when you suddenly lift off the pedal; letting the rpms drop suddenly can result in a rich mixture that polutes. By making the rpms hang a little, there is more complete combustion of the fuel for a cleaner burn and lower emissions.
Here is more info from another forum: http://www.elantraxd.com/forums/show...409&page=2
Here is a guy selling the plates for Elantras and Spectras (2.0L): http://www.elantraxd.com/forums/showthread.php?t=24364
And here is where the part is mounted on the engine (2.0L):
Old 10-03-2007 | 02:38 PM
richie's Avatar
Thanks for the suggestion,although the engine seems to have stooped holding the revs of its own accord (as it has in the past) and is now running sweetly.I'm a bit puzzled now as it has done this intermittently in the past,so would this suggest something sticking or possibly a fault somewhere ?
cgd
09-11-2021 03:17 AM
stan2121
06-26-2017 04:24 PM
WMCC
12-19-2014 08:36 AM
jakeg
01-12-2013 11:03 PM
idahotiburon
11-01-2007 10:26 PM
