Hyundai Coupe The European version of the American Tirburon.
Starting Problem
Old 01-16-2007 | 10:52 AM
Wolf359's Avatar
Default Starting Problem
Have a 1997 Coupe (1.6 litre) - recently it has been having problems starting - but it appears to be happening at random - sometimes it works, sometimes it doesn't - sometimes it takes a couple of attempts, sometimes it almsot bites, but dies, with just the starter still trying to get it going..Sometimes it won't start at all, but when you go back to it a few hours later it starts first time. Everything seems to be working - it just doesn't start.
Last weekI drove 125 miles to a meeting, meeting lasted 2 hours, car would not start afterwards. Starter worked fine, and it almost kicked in - eventually got it going with a push. Has been fine since then until this morning, when it just wouldn't start at all.
Well looked after, serviced annually.
Any ideas?
Old 06-18-2007 | 03:31 PM
chelle's Avatar
Default RE: Starting Problem
hi there i think i might be able to help ................ i had the same problem with mine ...................... try changing the crank shaft position sensor ................. you should be able to pick one up online for about 35 quid
rosie
08-26-2020 04:33 PM
landtuna
04-08-2008 11:51 AM
vinuge
11-30-2007 10:21 PM
martinv
05-17-2006 02:28 PM
sexysuzy
03-23-2006 07:58 PM
