01 elantra loss of power & backfire
Old 10-16-2019, 06:13 PM
Teresa Snedeker's Avatar
Default 01 elantra loss of power & backfire
Car runs smooth at idle and when cold once warmed up to running temp it loses power and backfires when trying to give it gas and also bogs down more. Has not stalled out yet, just acts like its going to. Replaced fuel pump, valve cover gasket, coil pack, plugs, wires, the coil pack electrical connectors, and tried a fuelx treatment.
Old 10-17-2019, 02:13 PM
If the engine is running lean result can be all the symptoms you described.
The better way to confirm fuel syst operation is to hook up a fuel pressure gauge and actually see what is going on.
If a fuel pump is not receiving a good ground connection , the pump doesn't work properly and a good working fuel pump gets replaced and the problem is still present, gets kinda expensive. You need to tackle one possibility at a time and verify correct operation then move on from there if necessary.
Old 10-21-2019, 05:35 PM
My old fuel pump was busted at the bottom, no matter what I've tried I still can find the issue.
Old 10-22-2019, 11:26 PM
avisitor's Avatar
How many miles on it?
And when was the timing belt last changed?
Have you cleaned the intake plenum?Throttle Plate?
Have you cleaned the Idle Air Control?
Old 10-23-2019, 06:07 AM
140,xxx. Just got the car in February don't know when timing belt was last changed. It's not stretched or anything tensioners seem good. I did spray carb cleaner into the intake and such.
Old 10-23-2019, 06:10 AM
Going to be testing the cats more today. I have to go out of state so need this car asap. Have noticed that when it acts up if I shut it off and start it right back up it seems to run fine for all of 2 or 3 seconds and goes right back to the same.
Michellebell
07-30-2019 09:19 AM
Caleb Green
07-18-2019 04:15 AM
makowski306
11-07-2017 03:19 PM
mike mcneil
05-28-2008 09:00 PM
Leejr57
11-18-2006 09:06 PM
Quick Reply: 01 elantra loss of power & backfire
