02 Elantra GT rear rotor/pad
Hi Guys,
I've got this vehicle from a month ago, so far so good.
And yesterday, i've tried to replace rear brake pad and found only right rear pad is very thin (2~3mm) but left pad is more than 5mm thick.
Also tried spinning rotors after rear jacked up, both right and left rotors spinning touching pad lightly once every turn.
I think there is something wrong with my rear rotor or pad.
I used to think my EGT has pretty soft brake, but someone can give an advice where to start?
I have replaced front rotor and pad when i bought this one but not rear.
And i don't have any vibrating issue when i brake on high or low.
Thanks in advance!
Thanks in advance!
RE: 02 Elantra GT rear rotor/pad
My guess is either one of the calipers is slightly dragging or possibly the emergency brake cable is slightly siezed. Make sure the sliders are propery cleaned and lubricated when replacing the pads.
word2yamutha
09-03-2015 12:17 AM
