03 Elantro won't allow vent selection
Old 01-08-2011 | 04:23 PM
tinskeep's Avatar
Default 03 Elantro won't allow vent selection
The heat control unit to select which vent does not work. Cannot select floor, vents, defrost, defost/floor. All it does is blow out the vents. Any suggestions???
Old 01-08-2011 | 05:29 PM
look at blend door motor for movement.. possible control head concern.. motor physically connected to linkage and door stuff ?
Old 01-09-2011 | 09:38 AM
tinskeep's Avatar
Haven't pulled apart yet. Hope to do so today and visually check to see what is going on and whether there is any movement as you suggest and linkage appears intact. I had same problem with Subaru except it blew out all vents so wasn't as big a deal. Ended up getting replacement from junk yard which worked great. I don't have defrost which is the problem and daughter heading back to College tomorrow. Also not sure what I will be looking at since never took apart before.
Thanks for your help.
tdi
janmarsh
11-04-2011 06:10 AM
tinskeep
03-05-2011 07:36 PM
mxm64
03-30-2008 11:36 AM
Majki
09-20-2006 03:12 PM
stlouiscards
06-07-2005 02:25 AM
Quick Reply: 03 Elantro won't allow vent selection
