07 Elantra Lights Exterior/interior not working
Old 06-26-2020 | 05:28 PM
One62's Avatar
The fusible link i meant was a 50a cartridge fuse. the b+1 has power on one side of the male connection in the fuse box, whereas the b+2 50a cartridge fuse has power on both. i am not sure how these fuses function as i think i should not have power present on both connections on the fuse box, but i have started to look around to see what all was done. it was said that a tech looked at it for a combination of 15hrs. and couldn't remedy it. i call BS, but i found a vampire bite that ran from a front wire that has switched voltage that runs to the rear tail light, another wire in the drivers side door panel feeding power to another plug in the door, i am starting to think i'm going to unravel a lot more of this before its all over. i think my solution will be to buy an add a circuit( you know, the plastic connection that allows for wiring another fuse in the box, like a littel fuse mini add a circuit card) for the 2 10a fuses labeled tail lamp LH and tail lamp RH, run those to a switch and add 12V to the switch and be done with it. that should work, and it will be double fused, from the switch side and the light side.
spencer115077
11-20-2015 11:30 PM
ssme
09-11-2012 12:08 PM
hinow41
10-30-2009 01:55 AM
jakeb157
06-15-2006 12:42 AM
CTtiburon2004
07-25-2005 07:43 PM
