1997 Elantra Close Canister Valve
Old 05-11-2009 | 08:06 PM
Green97GLS's Avatar
Default 1997 Elantra Close Canister Valve
My 97 Elantra GLS is giving a P0446 DTC
So I'm trying to find which Hyundai vehicles share the same Close Canister Valve and Purge Valve. I'm looking to find a these valve locally and replace them, likely from a donor car at a junk.
Any other parts you guys would suggest looking at in regards to this code?
Old 05-11-2009 | 09:30 PM
jsinton's Avatar
Banned
Go to car-part.com and search for general parts (like a transmission) for your car. It will give you a list of junkyards in your area where you can find your model car. Call the junkyards on that list, and ask if they are a "u-pull" yard. You'll find the car and you'll find the part cheap.
Old 05-11-2009 | 10:17 PM
ken99's Avatar
Code P0446 indicates a wiring problem with the purge valve, not necessarily a problem with the valve itself. I would check the wiring where the valve plugs into the harness first.
Attached Thumbnails 1997 Elantra Close Canister Valve-purge%2520control%2520solenoid%2520valve.jpg
Old 05-11-2009 | 10:37 PM
jsinton's Avatar
Banned
Ken, canister valve is different from purge valve. Canister valve is attached directly to the canister. P0446 specifies canister valve. Purge valve codes are like P0444 or P0445.
Old 05-11-2009 | 11:42 PM
ken99's Avatar
OK, to cover all bases, also check the harness connector to the canister close valve. On a 97 Elantra, the close valve can be found behind front bumper, below LH headlight.
Attached Thumbnails 1997 Elantra Close Canister Valve-canister%2520close%2520valve.jpg
Old 05-13-2009 | 09:27 PM
Green97GLS's Avatar
Default O.......Kay?
Now I'm a bit confused. To my understanding...the purge valve is under the brake booster, and the Canister Close Valve is in front of the driver side wheel in the bumper.
Is that right?
Is there anything to check for in the rear quarter panels?
Old 05-13-2009 | 09:43 PM
ken99's Avatar
Is that right?
Prior to 1998, the emissions control system components were mostly scattered around the engine bay. Since 1998, the bulk of the components have been consolidated into a package tucked up under the rear driver side corner panel. To double check, lay down and stick your head under the left rear fender and look up. The canister on the new systems is box shaped with the valves clustered on the top.
Old 05-13-2009 | 09:49 PM
Green97GLS's Avatar
Default ?
OK, my vehicles a 1997, would that apply for my car?
I have found and checked both the purge valve and the canister valve, and I can see no damage to the harness, and both units appear as though they've never been disconnected.
Perhaps it's the solenoid at the connector to the CCV?
How much would a new CCV be at Hyundai? Any idea?
Could code P0446 be anything else?
Old 05-14-2009 | 09:04 AM
jsinton's Avatar
Banned
The likely hood is either the CCV itself is bad, or the connection to it is bad (like a short in the wire you can't see). My next step would be replace the CCV as it's all one unit with the solenoid.
Old 05-16-2009 | 10:02 PM
Green97GLS's Avatar
Default CCV Replaced..
Ok i went to Hyundai today and got a new CCV, replaced. Cleared code with a scanner and the code came back P0446. Ideas?
