1997 Lantra (auto) won't go into drive immediately
Old 08-22-2011 | 02:29 AM
Metsavend's Avatar
Default 1997 Lantra (auto) won't go into drive immediately
Hi there,
I own a 1997 Hyundai Lantra with automatic transmission. When the engine is at air temperature and I put it in drive, the gears don't connect right away. I have to shift them through 1, 2 and D a few times and eventually it's OK after a few minutes, especially if I move the car of in 1 and shift up.
This problem doesn't occur if the engine is warm, even if it hasn't been running for a couple of hours.
Any ideas on what this problem might be and how to fix?
thanks very much,
Metsavend.
Old 08-22-2011 | 11:57 AM
jrstroh_96's Avatar
Have you changed your transmission filter. Your tranny maybe having a hard times sucking the fluid out of the pan. If you have you maybe having pump problems.
Old 08-22-2011 | 11:23 PM
ken99's Avatar
I agree with jrstroh_96 comments, but I would start by simply checking the fluid in the transmission. Low ATF levels will cause erratic shifting. As the fluid warms up it expands and shifting improves if the level is only marginally low.
Hatdrawn
04-27-2010 09:49 PM
tractorboy
03-30-2010 11:42 PM
turbo84
05-29-2008 04:25 PM
gatorwv
06-25-2007 05:50 AM
LYAL
04-22-2005 11:31 AM
