2000 Elantra Power window problem
Old 10-05-2010 | 07:53 PM
Hez37's Avatar
Default 2000 Elantra Power window problem
Hello, My 2000 elantra's windows are not working at all. Replaced the "multifunction" switch in the driver's door panel and that didn't fix it. Checked all the fuses and they are all good. My brother is going to be testing with a volt meter. Any one ever have this problem before? How did you go about fixing it? I would really like to get this problem figured out before the snow hits.
Old 10-06-2010 | 08:28 AM
It's probably the lift motor itself. You'll have to remove the door panel and test the motor.
Old 10-06-2010 | 03:54 PM
Hez37's Avatar
If all of them aren't working? It went out really slow. Started rolling down the driver's side and it just stopped and now all of them are not working. My brother has not got a chance to put a voltmeter on it yet.
Old 10-06-2010 | 06:48 PM
Hear any motor noise and binding crunching in the door... more common for the cables to fray tangle and lock up the works
Old 10-07-2010 | 07:42 AM
I didn't realize it was all windows. The title only said window (singular). Have you checked the 30A fusible link (not just the 10A fuse) and relay?
Old 10-13-2010 | 12:35 AM
hy-tech's Avatar
usually its a broken wire where the drivers door hinges to the body
if you remove the door the wires are easily fixed, the harness unplugs from the pillar ,just pull the rubber covering boot back to access
ShortBuSX
11-07-2020 09:46 PM
tgtrd
05-10-2009 05:20 PM
KnifeyMcShanker
01-27-2009 06:01 AM
01tiburon
01-04-2008 09:08 AM
hitmann123
11-21-2005 05:59 PM
