2002 GLS Stalling Issues
Old 10-11-2013 | 09:46 AM
Stamford's Avatar
Originally Posted by Erichshonda
When the fuel pump was replaced did you check for burnt terminals at fuel pump connection on top of tank? Also I believe the ground is right there under the carpet towards the center, make sure it's clean and tight. Burnt terminals and loose fitting fuel pump relays in engine compartment fuse box are problems I have found on numerous occasions. Need to perform a pin drag test on fuel pump relay terminals. If good, maybe it's a faulty relay
The terminals were good, but I have not checked the ground or relay and will do so. Could a relay cause an intermittent failure?
LRB
10-28-2014 02:17 AM
New Here
07-18-2012 12:20 PM
WoWitsMelvill
02-22-2012 12:11 AM
michaellawre
12-31-2011 01:32 PM
cory1848
10-22-2008 09:45 AM
