2004 Elantra GLS very low MPG
Old 10-11-2013 | 03:26 PM
firelink's Avatar
Default 2004 Elantra GLS very low MPG
I bought a 2004 Elantra this past August. It had minimal body damage, almost everything refurbished, and only had 66,000 miles on it.
The problem: I get ridiculously low MPG. I was wondering why I've had to put so much money into my tank lately, so I did a test. I filled the car up as far as it would go, and I set my trip to 0 miles. On my entire tank, I got a measly 215 miles. The tank holds 14.5 gallons, so that gets me around 14-15 MPG.
The car is rated at at least 21, and from what reports I've seen, can average all the way up to 26 to 29. I checked the oil/air filter and did an oil change just because. The air filter shows signs of wear, but nothing substantial, and the oil filter is like-new.
Any ideas?
Old 10-13-2013 | 09:55 AM
A lot depends on how and where you drive. Do you do a lot of high speed driving?
Old 11-08-2013 | 05:14 PM
jdmeaux1952's Avatar
I know this is over a month old. Check your brakes, especially your emergency brake cable. I had our's hanging an applying pressure to the brakes. (This was after I had a brake job done.) When the rear shoes were replaced, it appears they had a twist in the cable on re-assembly. This was causing brake drag.
agoudoulagig
10-16-2011 12:42 PM
BHarvey
11-22-2010 07:04 PM
tiBuronGt
01-03-2009 11:31 PM
CHIX
04-18-2008 07:43 PM
wuzzupall
01-10-2008 10:47 AM
