2005 Elantra Both lower brake lights out.
Hi to all. My 05 Elantra lower brake lights do not work, the upper one is ok. Just replaced both bulbs of the lower but still nothing. What is my next step? Is there a Brake Light Control Module somewhere? Fuse for Brake lights? I checked the fuse panel but did not see fuses related to brake lights.
Thanks for your help, pizzaman.
Problem solved. When I got home with newly purchased bulbs I noticed the packaging was taped as if it had already had been opened. Tried the bulbs and they did not work. So i remembered I had a bulb from my other Elantra and tried that. Bazinga! It worked. Went back and exchanged bulbs, now all is good. What a pain in the ****! My next step (after posing my problem here) was to take it to a mechanic. Then I would have told him I tried replacing the bulbs as first step and he would have probably proceeded to check elec system and so on, for absolutely no reason. Ugh!
Verminator
09-14-2011 02:03 AM
