2005 elantra idle surge
Old 07-22-2008 | 09:45 PM
gordonstafford's Avatar
Default 2005 elantra idle surge
For some reason, the engine revs up a bit at stoplights. Also, sometimes the engine dies when pulling in somewhere. Any idea what does this intermittent condition.
Old 07-22-2008 | 09:50 PM
Default RE: 2005 elantra idle surge
I'd check the IAC (Idle Air Control) valve first, then possibly the TPS (Throttle Position Sensor).
Old 09-21-2008 | 10:42 PM
I'm hearing so much that this could be the fuel pump. Would that make it rev to 3 grand at a stoplight.
Old 10-14-2008 | 09:54 PM
ceartly's Avatar
ORIGINAL: NovaResource
For a non-mechanic person, would it be worth it to research and troubleshoot myself? Or should I have my mechanic take a look? The same thing is happening on my '04.
Thanks!
Chaz
Old 10-15-2008 | 12:11 AM
ken99's Avatar
I agree with NovaResource's diagnosis, but I suggest you check for a vacuum leak first. It's an easy first step and cheap to fix if such is the case. Sometimes the IAC or MASS air flow sensor get confused when a quantity of "unmetered" air is getting into the engine.
No, I do not think such would be the case.
NR forgot to suggest that a code scanner be used to pull any error codes residing in the cars computer. Many auto parts stores will do this for free (hoping to sell you a part). Sometimes their interpretation of codes is good, sometimes it is not. If you do get some codes, many forum members will try to help you sort them out if posted. Yes, take the car to a mechanic if you feel you are over your head.
Old 10-15-2008 | 07:40 AM
ORIGINAL: ken99
Good advice. First check the vacuum lines for leaks and get a basic code scanner. It is an excellent tool to have.
stocks101
06-13-2014 10:36 AM
PHWong
03-23-2013 11:28 AM
fredcat
08-17-2007 11:06 AM
Matthew
03-26-2007 10:05 PM
macpowell
08-28-2005 04:32 AM
