2005 Elantra Radio
Old 09-17-2011 | 12:38 PM
krnlds's Avatar
Default 2005 Elantra Radio
This will be a shortlived thread I believe but can someone please send me visual instructions on how to remove a stereo from an 05 Elantra?...I found printed instructions on-line but I kinda need visual as well
Old 09-17-2011 | 06:41 PM
REMOVAL
1.Disconnect the negative(-) battery terminal.
2.Remove the 2 screws(A) holding the instrument facia panel.
3.Open the ashtray then remove the ashtray assembly after pushing the plate down.
4.Remove the 2 screws(A) after removing the ashtray.
5.Disconnect the connectors from the instrument facia panel.
6.Remove the audio unit(A) after removing 4 screws.
7.Installation is the reverse of removal.
Old 09-18-2011 | 09:02 AM
krnlds's Avatar
Thanks a ton for the info...I got the stereo out and have the wiring harness set up for the new one but it won't turn on, and there are same colored wires for different functions, NO WONDER they charge so much to do this kind of work...I'm not a hundred percent sure if i got the wire right, I mean I'm certain I got the power and ground correct. Any thoughts?
Old 09-18-2011 | 01:30 PM
shinnoch's Avatar
Old 09-19-2011 | 08:28 PM
krnlds's Avatar
you guys ROCK thnx for the help....I'll set it in thursday....thanx
William Alexander
04-24-2015 12:13 AM
daniel2229
11-13-2014 04:28 PM
brad13
06-11-2011 07:03 PM
begs
04-05-2010 11:07 AM
MrFlashport
09-01-2007 10:59 AM
Quick Reply: 2005 Elantra Radio
