2013 Elantra AC Problem
Old 05-13-2018 | 11:46 PM
Chris M.'s Avatar
Default 2013 Elantra AC Problem
Have an 2013 Elantra GLS with an AC issue. When parked or stopped and idling AC works like normal, cold air. When driving below 40mph AC works intermittently (more off than on), cold air...then outside temp air (recirculation not on) or internal air temp (recirculation on). Above 40mph nothing at all. May come on if AC button is turned off for 3 seconds then turned back on. Seems as if AC turns on (or blows cold air) when radiator cooling fan kicks on. Hard to diagnose since at idle works fine. Replaced expansion valve. Refrigerant is at spec. Looking at replacing pressure sensor. Then compressor. Not sure what to try next. Any suggestions?
thedoctor63
05-15-2018 07:27 PM
asjadazeez
04-12-2018 10:21 PM
nukerdan
05-22-2017 07:01 PM
lizziedunn
03-07-2016 05:18 PM
Azbrokeer
11-09-2013 10:55 PM
