95 Elantra, No start
I'm working on a 95 Elantra. While diagnosing a no start issue, dicovered the fuse on the positive side of the battery was fried, replaced it. Then discovered the ECM was fried, replaced it. Now I have spark and fuel but still won't start. One other thing, the car has an aftermarket radio installed, radio keeps blowing fuses. when I change the radio fuse, as soon as I turn the key on the fuse blows immediately. Any ideas??
RE: 95 Elantra, No start
Ref no start, if you have spark and fuel it sounds like you have probably got a timing problem, possibly firing with exhaust valve open.
Ref radio, could be the unit is shot or is wired incorrectly, power is going straight to earth.
Hope this helps,
Chris.
Hope this helps,
Chris.
