99 Elantra - clutch slipping!!!
Old 03-02-2007 | 03:10 PM
zeke's Avatar
Default 99 Elantra - clutch slipping!!!
My transmission (clutch) slips upon acceleration. About1 year ago, I had the clutch replaced, except for the flywheel, which was resufaced.
It worked great for a few months, then started doing it again.
A technician adjusted the master cylinder under the dash, and it worked great again... for a few months. But now the cylinder can be adjusted any way, and is not fixing the problem, or even the symptom.
Does anyone know if this is a master cylinder problem, or a mechanical problem at the clutch/transmission?
HELP, PLEASE!
Thanks,
Zeke
Old 03-16-2007 | 02:05 AM
MJBooker's Avatar
Default RE: 99 Elantra - clutch slipping!!!
Could be the pressure plate getting weak. After so many ins and outs the springs get weak, plus the heat helps take a toll.
It is usually a good idea to replace both pressure plate and clutch.
steve16
10-20-2011 10:18 AM
zappyisfun
10-27-2009 05:57 PM
gardengirl28
04-28-2009 12:12 PM
c00lnerd
02-25-2008 01:04 PM
kaz777cars
04-19-2007 04:57 PM
