99 Hyundai dies when slowing down
Old 04-13-2009 | 08:31 PM
mattr's Avatar
Default 99 Hyundai dies when slowing down
Car has 233,000 on it. Up until 1 month ago nothing wrong, now sometimes it won't start--cranks over but won't fire--also when driving it sometimes just dies--then it won't start. It has 4 codes PO722, PO727, PO441, PO335.
Any suggestions?
Old 04-13-2009 | 09:48 PM
cmas1975's Avatar
P0722 is a transmission pulse generator B, (speed sensor) can get only at a dealer of like $55.00 USD i don't know what the other codes are, hope i could help
Chris
Old 04-13-2009 | 09:55 PM
jsinton's Avatar
Banned
Good going getting the codes. It tells the whole story.
P0722 - Output speed sensor no signal.
This is the a speed sensor on the transmission. It's the output one on the back near to the axles. It's either bad or connection to it is no good.
P0727 - Engine speed input no signal.
Not sure what this one it, but it's serious. It's a transmission sensor, but I don't know which one.
P0441 - Purge valve incorrect flow - It's the EVAP system, probably a hole in the purge valve hose. It won't impact engine performance.
P0335 - Crankshaft position sensor malfunction.
This is your problem. Replace this part. Possibly the same sensor as P0727.
Hyundai Ty
10-04-2014 04:14 PM
Jack Seeders
04-20-2013 09:03 PM
burtonsnow2002
11-29-2011 08:44 PM
Rhondas
11-07-2008 05:51 AM
boilerman
08-06-2008 05:07 PM
