Clock/radio/trip computer resetting
Old 03-25-2011 | 09:25 PM
papabear0276's Avatar
Default Clock/radio/trip computer resetting
My Brand new Elantra Limited (34 miles on odometer) is resetting the clock, radio presets and the trip computer after shutting down.
Doesn't happen right after shutting down, but if it sits for a while it resets everything but the navigation system. Will be calling dealership in the morning. Anyone else have this problem?
Old 03-25-2011 | 10:17 PM
There is a jumper/fuse in the fusebox that is supposed to be pulled up or out (2 different types depending on car) to disengage it by the dealer as part of the dealer prep. This jumper/fuse protects the battery from being drained by things like the radio memory during shipping and storage. The dealer probably forgot to do it. Take it back and have them fix it. You you could take a look at the fuse box. Look for a big yellow jumper.
Old 03-25-2011 | 10:37 PM
That was it, Big yellow 'On' 'Off' Switch in fuse box. Flicked it to on- all is right w/the world. Thanks for saving me a phone call/trip back to the dealer!
Old 03-26-2011 | 10:55 AM
bigdogbitu's Avatar
Default Switch
Several of us had this issue at first too. Simple fix!
Old 02-08-2012 | 08:35 AM
Corinna.ah's Avatar
Exclamation Not the solution!
I had this very same problem that left me stranded at 11pm in a bad part of town where I worked as a retail manager. Apparently when it does this reset my lights come on, which drains the battery. They say it was because of this dealer switch. switched it. Had to call several weeks later because I was still having the same problem. They couldn't tell me what was wrong with it. I've now had the car for 6 months. And I'm sitting at home researching what I could possibly do to fix this problem when I should be at work, but don't have the transportation to get there because my 2011 Hyundai Elantra limited, just 6 months old, won't start. I would like a REAL solution because this dealer switch, didn't do diddly squat.
Old 02-11-2012 | 01:10 AM
Byrnsy's Avatar
Default damn yellow switch
I had exactly the same problem but is now fixed thanks for help
sydneyk24
10-18-2009 07:00 PM
mightyelantra
12-26-2007 11:51 PM
vasilaras
10-02-2007 04:53 PM
jdorton
02-13-2006 06:45 PM
meld3
10-23-2005 10:54 AM
