Code U0D07???
Old 08-18-2010 | 10:56 AM
gstone's Avatar
Default Code U0D07???
I have an engine warning light on in my 2001 Elantra. When I scanned, I got a code of U0D07 but have not been able to find what such a code means. Does anyone know?
Thanks.
Old 08-18-2010 | 11:42 AM
Not a valid code, you is wanting a "P" (powertrain) -xxxx type code (x's = digits)..
Old 08-18-2010 | 12:58 PM
Thanks.
What scanner did you use? First, I'd suggest a new scanner because there are no "U" OBD-II codes.
BXXXX = Body Codes
CXXXX = Chassis Codes
PXXXX = Powertrain Codes
(XXXX = numbers, no letters)
Old 08-21-2010 | 04:08 PM
gstone's Avatar
Default Code issue
I have a 2001 Hyundai Elantra with the engine maintenance light on. I used a ScanGauge II to find the code. I got U0D07. I reset the car and checked when the light reappeared with the same code result. What does this code indicate?
Thank you!
Old 08-21-2010 | 04:31 PM
Thank you!
Re-read posts 2 & 3 above....
I want to see a P-xxxx type code, then I can tell you where to start.
As "Buddy" over at Sturm says --> "Help us to help you"
Old 08-21-2010 | 05:47 PM
Let me see if I can say this again so you will understand:
U0D07 is not a valid OBD-II code. Use a different scanner.
That U code is a communication error with the ScanGuage II.
Old 08-22-2010 | 10:05 PM
gstone's Avatar
Default OBD code
I used two different ScanGuage II units, both reading the "u" code.
I assume there is a problem with the output plug connection under the dash. Is there another output plug connection under the hood (like on my Toyotas)?
Old 08-23-2010 | 07:05 AM
(5) day now and you cannot drive through a Auto-Zone, Advanced Auto or Pep Boys for FREE scan and get a P-xxxx code(s)...
Old 08-23-2010 | 07:08 AM
No, there is only one OBD-II port and it is under the dash. Forget the ScanGuage. Get the computer read by a real OBD-II code reader. Hyundai cars require a special (read: different than normal) cable to connect the ScanGauge.
Old 08-23-2010 | 05:22 PM
gstone's Avatar
Thank you.
Quick Reply: Code U0D07???
