Ecu elantra 2010 1.6l
My ECU was stolen, my car Hyundai Elantra 2010 - Engine 1.6L AT.
I don't found this original Number Part ECU = 39120-2B012.
I buy this Numberpart 39150-23161 but not Star Car.
If anyone Knows anything shortcut or possible solution.
If the person that stole your vehicle's PCM doesn't know , it is going to cost them $$$ to use it.
Any PCM has to be programmed with a special tool and information which also will cost some $$$ before it can even get the vehicle started.
You need to check with your local dealership to get a correct replacement and it has to be programmed to your particular vehicle. There is no other way to do this !!
Sorry to have to give you this info, but there is no other way to correct this. That PCM is useless to the other person unless it can be programmed to a particular vehicle. This is supposed to discourage theft, but the crooks either did not know this or are connected to someone that can do the reprogramming .
