Elantra emergency brake cable replacement
Old 08-19-2007 | 10:14 AM
dek2904's Avatar
Default Elantra emergency brake cable replacement
Hello forum,
Does anyone here have exprience of replacing Elantra handbrake cable?
My Elantra is 2003 2.0 diesel.
I have one cable snapped.
Cheers DH
Old 08-19-2007 | 02:45 PM
nwitous's Avatar
Default RE: Elantra emergency brake cable replacement
It should still be under warranty. Take it in to your local Hyundai dealership and have a professional take a look at it for you.
~Nic
Old 08-20-2007 | 02:50 PM
Doohickie's Avatar
I second that, but if it is not in warranty, I would think it is a job you could do yourself. If you remove the rear wheels, you can see the attachment for the cables. I think removing one screw is necessary to alow the attachment to swing and free the end of the cable. At the other end, removing the center console is pretty easy; just three screws on each side near floor level, and lift over the gearshift and brake handle. If you're going to do it yourself, I might be able to find a procedure for adjusting them.
Old 08-20-2007 | 04:54 PM
dek2904's Avatar
Thanks guys....did the job meself and it was quite straightforward..warranty is now kaput after disgreement with Hyundai over what exactly constitutes broken or worn parts..
shepshep60
04-27-2021 02:15 PM
dizzle
09-07-2020 03:20 PM
Rhanck
09-03-2011 08:41 PM
astrat16
10-05-2010 07:48 AM
holt3332
09-30-2009 08:27 AM
