Error codes and confusing situation
Old 11-18-2008 | 12:59 PM
knightspeed's Avatar
Default Error codes and confusing situation
Hey i have a few questions first off i have a 2000 hyundai elantra with around 122k miles on it i recently started having a shakey motor, so i went to autozone and checked the error codes, i got a p0300 p0301 and p0304 code which i found out was a misfire of the system i checked on here and on other forums for what i can do, the misfire is the problem. I have recently replaced the plugs wires, fuel injectors, and fuel filter in the car, and it still misfires, i checked on here and it says that there is a vacum line is open i have been looking for it but i cant find which one can be. all i know is i rechecked the plugs and 1 and 4 has carbon tracking on it, and i checked for arching on the wires and nothing. and i know the injectors are working. so i dont know what else to do please help.. I appreciate any insight or queries to help me resolve this problem
Old 11-18-2008 | 03:07 PM
ken99's Avatar
Default RE: Error codes and confusing situation
You likely need a new coil pack. Cylinders 1 and 4 are misfiring, which are served by the same side of the coil pack. To test the coil:
2000 > G 2.0 DOHC > Engine Electrical System
MEASUREMENT OF THE PRIMARY COIL RESISTANCE
1.Measure the resistance between connector terminals 3 and 2 (the coils at the No.1 and No.4 cylinder sides) of the ignition coil, and between terminals 3 and 1 (the coils at the No.2 and No.3 cylinder sides).[/align]
MEASUREMENT OF THE SECONDARY COIL RESISTANCE[/align]
1.Measure the resistance between the high-voltage terminal for the No.1 and No.4 cylinders, and between the high-voltage terminals for the No.2 and No.3 cylinders.[/align]
Be sure, when measuring the resistance of the secondary coil, to disconnect the connector of the ignition coil.[/align]
gjz30075
12-27-2011 07:58 AM
JACK6306
05-10-2009 11:05 PM
formula40
01-19-2009 11:54 AM
pickleweed
05-21-2008 12:16 PM
nmunafo
01-17-2008 08:49 AM
