front wheel squeak/screech
Old 07-21-2006 | 09:31 AM
pecos's Avatar
Default front wheel squeak/screech
Just bought a used 2000 elantra. Yesterday I noticed a squeak/screech coming from the right front wheel when moving. It stops when brake is applied, but starts again when I let off the brake pedal. I thought of brake wear indicator, but doesn't that usually happen when brakes are applied instead of when they're released? Thanks!
Pecos
Old 07-21-2006 | 09:26 PM
kuyi84's Avatar
Default RE: front wheel squeak/screech
I had a similar occurance with my '03 elantra. What was causing the noise in my case, was the the cushion between the rotor and the break pad had worn away, so the edge of the pad was rubbing against the rotor.
ryanof
04-30-2014 03:08 PM
twincitybulldog
04-18-2012 07:11 AM
lavarc
04-07-2012 04:30 PM
shadango
01-17-2011 09:02 AM
marcsyl
09-21-2008 03:52 PM
