Fuel Pressure Check
Old 12-27-2009 | 01:41 AM
romeroom's Avatar
Default Fuel Pressure Check
OK, I'm new to my 2000 Elantra. So stupid question here: How do you check the fuel pressure on this car? I can't seem to locate any sort of port (schrader valve) to connect the "usual" pressure gage.
Can someone help on this? Thanks.
Old 12-27-2009 | 11:46 AM
ken99's Avatar
From http://www.hmaservice.com for a RD model Elantra (1996 thru 2000). Look under "SHOP > ELANTRA(RD) > 2000 > ENGINE > G 2.0 DOHCFuel System > Fuel Delivery System > FUEL PRESSURE TEST" for a full discussion of diagnostics and corrective actions.
FUEL PRESSURE TEST
Safety glasses must be worn when performing the service as follows.
1.Reduce the internal pressure of the fuel pipes and hoses by the following procedures.
a.Disconnect the fuel pump harness connector after removing the rear seat cushion
b.Start the engine and after it stalls, turn the ignition switch to the OFF position
c.Disconnect the battery negative (-) terminal.
d.Connect the fuel pump harness connector.
2.The fuel filter is located in the left side of the rear quarter of the engine compartment.
3.Remove the single tie-wrap that secures the fuel pressure line to the fuel return line.
4.Remove the electrical connector from the master cylinder reservoir below.
Before proceeding to the next step, place shop rag over fuel filter to capture fuel spray.
5.Move shop rag enough to expose bolt on top of fuel filter, remove bolt and line from filter.
6.Using the fuel pressure gauge, gauge connector and gauge adapter (09353-24000, 29000), install the fuel-pressure gauge to the fuel filter. Tighten the bolt to the specified torque.
7.Connect the battery negative (-) terminal.
8.Start engine and check for leaks. If no leaks are present, continue with fuel pressure test (at curb idle speed).
9.Connect (disconnected) the vacuum hose from the pressure regulator (and plug the hose end). Measure the fuel pressure.
Old 12-28-2009 | 08:55 AM
romeroom's Avatar
Thank you, Ken99. Huge help.
Non_Affiliated
10-31-2019 08:39 PM
bigjdog
10-26-2010 10:21 PM
bobsod
07-15-2006 03:37 AM
bobsod
07-14-2006 01:00 PM
Fairfax
12-19-2005 09:34 PM
