Help! 99 Elantra Bogging Under Acceleration
Old 10-17-2007 | 09:31 PM
99_elantra's Avatar
Default Help! 99 Elantra Bogging Under Acceleration
Hi,
Are there any hyundai mechanics on this forum? I am having a difficult time diagnosing a problem with a 99 elantra. When the car is cold it runs fine and I can accelerate full throttle with no problem at all. Once the car has warmed up it starts acting very strange under acceleration and even stalls at times. If I keep the accelerator at say under 10% throttle position the car seems to want to drive ok but any kind of load and the car acts as if it loses fuel or ignition. I have ruled out ignition due to the fact that I have replaced the plugs/wires and coil packs. I hate to say this but I am stumped. If it was the fuel pump it either works or it doesnt. I have read about sensors but why only when the car has reached temperature. I read about grounding issues and I added a ground from the chassis to the engine. Still no change....please help me out here I am at a loss. Has anyone experienced this with hyundai? I am about to junk this friggin car but i know it is probably something simple. I would love to hear from a hyundai mechanic on this one, been working on cars for years and I cant figure this one out. oh i almost forgot....no check engine light with all of this...wtf?
Old 10-17-2007 | 10:55 PM
WheelBroker1's Avatar
Default RE: Help! 99 Elantra Bogging Under Acceleration
Hello member:
I'm thinking that you are having a fuel clogging issue here, have you changed your fuel filter?
Also have you checked your fuel pressure at the fuel rail to see what pressure your getting?
WheelBroker1 [sm=americanasmiley.gif]
Old 10-18-2007 | 09:16 AM
99_elantra's Avatar
Thanks for the reply Wheel. I am begining to think the same as there is no check engine light being triggered. If I were having an issue with a sensor my CEL would trigger right? I will try to check pressure at the fuel rail this weekend. Is there an easy way to do so or do I have to run a "t" to a gauge? I appreciate your help. Oh and yes the very first thing i did was change the fuel filter... Thanks..Rob
Steve0321
08-04-2013 02:19 AM
Weaponhead
07-25-2012 08:27 PM
knothead
03-08-2012 05:31 PM
gorgegranny
01-26-2011 11:05 PM
zierk0310
08-02-2007 06:24 PM
