Idle Air Control (IAC) valve issue??
Old 02-27-2012 | 12:35 PM
YvesS's Avatar
Default Idle Air Control (IAC) valve issue??
Hi.
I have an Elantra 2000. The issue is intermittent. In the last year, we had the issu several times but after trying and trying, the engine would always finally start.
But 2 days ago, we were unable to start the engine. All the normal noise was there when we turn the ignition key but won<t start. I noticed that the IAC was making a buzzing noise (even when I had the keys removed from the ignition). What I finally did is unplug the IAC, tried to start the engine and this time it was different. The engine kind of started for a quarter second and stop. Did that a couple times. Plugged back the IAC cable. Turned the ignition key and it started like a new 2012 Elantra!
I am ready to buy and replace the IAC but after reading some sites, I have lost the 100% certitude that I have found the problem now I have some doubts that it might be a coincidence.
Does someone know if a bad IAC will prevent an engine to start or just cause problem when the engine is on idle^
Thanks in advance for you help.
Yves
mariawhite
01-09-2013 10:12 AM
riebe
07-03-2012 12:47 PM
HangingAround
09-10-2009 03:47 PM
treyclash
04-08-2008 08:52 AM
seabrooke
10-03-2007 07:18 AM
