Low Acceleration after stoping
Old 08-08-2020 | 02:06 AM
SportsDude's Avatar
Default Low Acceleration after stoping
I have a 2008 Elantra 2.0 with an acceleration issue.
After I drive it for 30-45 minutes and come to a stop, I push the accelerator down and it doesn't move hardly at all. It is like the car is moving at half the speed when I push down on the pedal. When it is cold and I come to a stop, I can push down on the pedal and there are no issues at all. It is hot where I live (110F) and this only happens when the engine is hot. If I drive it home and let it sit for 20 minutes then it is fine.This car is only drive once every 2-3 weeks.
Does anyone have any thoughts on what it could be?
I took it to a repair place, but they said since there is no check engine light, or there isn't a constant issue, then they will not be able to figure it out and they will go on a wild goose chase.
Old 08-08-2020 | 09:08 AM
avisitor's Avatar
Sounds like a possible fuel delivery issue.
Say when the engine is cold, the fuel pump is working fine.
After a while the fuel pump doesn't put out the same pressure.
So, the engine can not accelerate as normal.
To test this theory, need to put a pressure gauge on the fuel rail and watch for when it happens
If the fuel pressure is low when you have this issue then the fuel pump would be suspect.
If it is not then must look else where.
Good luck.
Old 08-08-2020 | 11:33 AM
SportsDude's Avatar
Good luck.
Thank you so much for your reply I really appreciate it.
Old 08-09-2020 | 09:08 AM
avisitor's Avatar
A sticky IAC can also have similar issues.
That just takes a can of spray cleaner (Brake clean, carb cleaner)
Spray the IAC and work the valve
While you are there, might as well clean the throttle plate
Good luck.
pdonoho
04-14-2019 04:22 PM
nickaz2013
08-18-2013 12:14 PM
saugen48
07-27-2012 09:01 PM
mangusm1
12-18-2008 11:56 AM
mrchris
12-30-2007 02:21 AM
Quick Reply: Low Acceleration after stoping
