Misfiring in Cylinder 1
#11
Hi, So we have already removed the injectors the check that they are working, all is fine there, only thing that has made some kind of change. Was when we removed the tappet cover to see that all is good with the valves and rockers. when placing the cover back and only holding is down the the car run like normal, started at once. After tightening the cover back the same problem occurred. I have spark, the cords are working, the coil is working and have good compression. But i still do not have firing on the one piston.
#14
speeder
03-09-2008 08:05 PM
