my elantra help please
Manual or automatic transmission?
Either the hydraulic clutch is not working correctly or the clutch itself is worn out. Start by checking the fluid level in the reservoir on top of the clutch master cylinder. If low, fill with DOT 3 fluid. Because of the excess slippage when the clutch is released, I suspect the slave cylinder is hanging up, or as I said before, the clutch is gone.
Confused975
01-18-2009 08:28 AM
thekarshop
08-01-2008 07:49 AM
