Need Advice, doing body work myself.
I rear ended someone the other day and didn't have collision on my insurance. I've got a 99 Elantra and I'm trying to get all the bad parts off so I can see what's left. I've gotten down to the radiator support but it's apparently not a bolt on item like everything else. Does anyone know if I'll need to have it cut out and the new one welded in? Is this the part I need?
http://www2.partstrain.com/partlisting/full/hyundai/elantra/radiator_support/1999/2000.html?ptc=S1171391678W45d204bec356b&ptk=19 99+2000+Hyundai+Elantra+Radiator+Support+-+Hyundai+99+00+Radiator+Support
Here's what it looks like right now. Still runs! Of course the radiator fans aren't working as they're wedged into the exhaust manifold right now.
RE: Need Advice, doing body work myself.
If you do decide the cut the piece, spend some time prepping the car. The piece you are removing supports the radiator, but also supports other structures to keep them from flexing. Basically, it forms one end of a box around the engine compartment and you don't want the "side walls" flexing or "caving" in as it is removed. You want to stabilize the front section as best you can so hopefully nothing gets tweaked out of place by gravity when the front support is removed. You do not want the weight of the car siting on the front tires. Block it up on stands and position them close to where the lower swing arms attach to the body. I would also try to get blocks under the motor and tranny to help take their weight off the structure. Also, take some angle iron or tubing and fashion up a brace that you can bolt between the shock towers (or buy a fancy one for the car that you can leave in after the job is done). You may need to clamp a similar support between the fenders in front of the engine. Keep a good tape measure handy. As you start to tack the new piece into place, you'll need to constantly measure criss-cross between points on the front and on top to make sure the structure stays square and as true as possible.
Good luck on this project.
