New Motor
Old 03-19-2008 | 02:01 PM
andrewt48's Avatar
Default New Motor
Hi. I just bought an 04 Elantra GLS about 3 weeks ago. I took it in because of a sound it made while cold and they said I need a new motor because of a bad wrist pin? Anyone else had this problem? Should I be worried about getting a new motor? Does it effect the title on the car? Thanks for any help on this issue.
Old 03-19-2008 | 10:00 PM
ken99's Avatar
Default RE: New Motor
How many miles on the odometer?
Old 03-20-2008 | 11:13 AM
madindian1's Avatar
could be a bad wrist pin like they said or thrust washer fell out causing the noise. does it make noise all the time? getting an engine doesn't affect the title. also if it needs wrist pin best bet is to get a used engine, easiest fix.
Old 03-20-2008 | 11:24 AM
andrewt48's Avatar
Its only got 39K, so its still under warranty, so the dealer is going to do it for free...I was just worried about any other issues I should be aware of.
The problem itself I wasn't so sure was a wrist pin...the noise goes away when the engine gets warm, oil pump, lifter issue?...but I wasn't going to argue if they wanted to put a new engine it.
Is there anything else I should ask the dealer about? Thanks
Old 03-20-2008 | 03:21 PM
ken99's Avatar
If the dealer is replacing the engine with a new one under warranty, you are in good shape. Find out if they replace the timing belt or not. I'm guessing they will, but make sure so you know when the correct service interval (in terms of mileage) will happen for the belt.
Don Duvall
08-18-2018 02:29 PM
andrewt48
03-19-2008 04:20 PM
TSD_GS
09-19-2007 07:50 PM
mr.motors
08-28-2006 03:24 PM
tomcat
05-24-2006 03:59 AM
