New plugs, what to set the gap at??
Old 05-29-2005 | 04:25 PM
Quattrocket's Avatar
Default New plugs, what to set the gap at??
I just picked up a set of bosch platinum plugs for my girlfriends 99 elantra, what should i set the gap at???
Old 06-07-2005 | 11:36 PM
hyundai tech's Avatar
Default RE: New plugs, what to set the gap at??
Proper plugs for the vehicle are NGK. Those bosch will cause hesitation upon acceleration. Anyway if you want specs you can look them up at www.hmaservice.com.[]
Old 06-12-2005 | 07:03 PM
Wanabefastrtibby's Avatar
Do NOT..I repeat .....DO NOT put those peice of crap Bosch plugs in the car , they heat up in the center and cause crappy misfire occurances ,and like tech said they do not work properly at all...I dont know who these freekin checker and auto Zone dorks are ........but man they must have an over stock on them things.I've had to redo more customer doit yourself tuneups because of them things, juz get NGK or if ya must Denso.........the work the best for these cars because they're made for these cars
Old 06-17-2005 | 03:50 AM
pure performance's Avatar
Ya platnum plugs suck holdway to much heat and cause preignition! And plug gap is ushall right under the hood located by the hood relese
Old 03-14-2006 | 11:56 PM
kuyi84's Avatar
has anyone heard of the splitfire spark plugs? can these work in an elantra engine??
Old 03-16-2006 | 03:56 AM
poacher's Avatar
I have used the platinum fours and they work great. As for the gap......it's a platinum plug, it doesn't need gapped.
Old 03-19-2006 | 11:28 AM
flave1's Avatar
ORIGINAL: kuyi84
dont bother with these they are overpriced crap stick to the standard ngk bkr5e-11 and the 11 stands for the gaps (1.1mm)[sm=badidea.gif] they are just as good if not better and cheaper.
Old 09-19-2006 | 11:48 PM
bodman75's Avatar
I also just purchased the Bosch Platinum + 4 Plugs in my 04' Elantra and I've had no problems and you do NOT need to set the gaps.
05kas05
03-04-2012 02:52 AM
Hicks37
05-31-2010 09:15 PM
mr.motors
08-28-2006 03:24 PM
praefect
04-07-2006 05:21 PM
Quattrocket
12-09-2005 12:16 PM
